iRule hashing + trim
Hello Devcentral community,
Please can you tell me how to a hash a variable like the sha 512 (i store a certain parameter value by the uri ) and after that i want to keep only the last 10 characters of the sha.
Variable Variablehash--> hashed sha512 of $variable
Than, only the last 10 characters of the $Variablehash
One more question: how i can inspect the response page that returns to the client ( passing from the BIG-IP ) and if a certain string in the HTML body is present than i ll generate a message ( hsl)?
Thanks in advance,
Best Regards,
Matteo
Hello, anyone can give me a suggestion ?
Try this for your hash variable:
set variableHash [sha512 $variable]
set lastTenHash [string range $variableHash [expr [string length $variableHash] - 10] end]
For your response you would need to do a
HTTP::collect [HTTP::header Content-Length]
in your when HTTP_RESPONSE event and then in the HTTP_RESPONSE_DATA event you would need to inspect the HTTP::payload for your string probably using scan. Be weary, that this will collect the whole payload of every response which could be a performance hit to the application.
