Is this possible…
Add the following irule to the gtm wide ip address..
if { [TCP::local_port] equals "9074" } {
HTTP::redirect “test.com; } }
Then on the test gtm address pool have the members service port as *.
Is this possible…
GTM does not process HTTP traffic, so this event will never fire.
A wide IP is a point of DNS resolution and has nothing to do with ports. If you simply want to redirect to another URL, then you can do that in the LTM iRule and simply have GTM resolve the IP address of that URL.
So i can’t write an irule that checks the port coming in and if its 9074 then its sends it to a different url which happens to be a gtm address. Currently the vip etc only services port 80 traffic
Sure you can. The iRule you had in the first post would do that.
HTTP::redirect "http://test.com"
If the request is for the 9074 local port, redirect the client to http://test.com. GTM would resolve http://test.com to a different IP address.
Well, yes, if the VIP is only configured for port 80, it will ignore any other port traffic. If you need to capture port 9074 requests, then perhaps you need to configure the VIP with a wildcard port and use an iRule to restrict it:
when CLIENT ACCEPTED {
switch [TCP::local_port] {
"80" -
"9074" { return }
default { drop }
HTTP::redirect "http:://test.com"
