We have a F5 ASM and LTM module implemented on AWS Cloud. The public traffic to our application server passes through F5. My requirement is to block the traffic with URL starting with https://www.abc.com/.b How do I achieve this ? Is iRule or ASM is the best suit for this ? What is the Irule configuration for this?
Unlike the ASM suggests in this configuration, I have this as disallowed URI rather than disallowed URL.
So, if I thinking to that policy is to unique host/domain and that disallowed URI is explicit, I’d prefer to set in ASM “Disallowed URL” settings. So, I’m not sure about command to trigger ASM to block, just to unblock. Thus, you may need a second policy or some logic into the iRule to register the violation as an ASM event log, otherwise, you’ll just drop the request and register “syslog”, if needed.
It’s just a point of view.
Regards.
