iRule for uri rewrite only for selected uri paths and keep the same url for all other cases
Hi Friends,
Could anyone please suggest me an iRule which will only rewrite uris for selected uri paths and keep the original url same for all other cases.
ex: I want the uris to be rewritten only for the below 2 cases and all other cases should be kept as is.
domain.com/abc → domain.com/hij
domain.com/def → domain.com/klm
All other request should be same such as if the original request is domain.com/123 → it should remain same as domain.com/123
Any help would be greatly appreciated.
Regards
Kiran
e.g.
[root@ve10:Active] config  b virtual bar list
virtual bar {
   snat automap
   pool foo
   destination 172.28.19.252:80
   ip protocol 6
   rules myrule
   profiles {
      http {}
      tcp {}
[root@ve10:Active] config  b pool foo list
pool foo {
   members 200.200.200.101:80 {}
[root@ve10:Active] config  b rule myrule list
rule myrule {
   switch [string tolower [HTTP::uri]] {
      "/abc" { HTTP::uri "/hij" }
      "/def" { HTTP::uri "/klm" }
 /abc
[root@ve10:Active] config  ssldump -Aed -nni 0.0 port 80
New TCP connection 1: 172.28.19.251(50703) <-> 172.28.19.252(80)
1366693438.9012 (0.0010)  C>S
GET /abc HTTP/1.1
User-Agent: curl/7.15.5 (i686-redhat-linux-gnu) libcurl/7.15.5 OpenSSL/0.9.8b zlib/1.2.3 libidn/0.6.5
Accept: */*
Host: domain.com
New TCP connection 2: 200.200.200.10(50703) <-> 200.200.200.101(80)
1366693438.9033 (0.0018)  C>S
GET /hij HTTP/1.1
Accept: */*
Host: domain.com
 /something else
New TCP connection 1: 172.28.19.251(50704) <-> 172.28.19.252(80)
1366693465.1440 (0.0009)  C>S
GET /somethingelse HTTP/1.1
Accept: */*
Host: domain.com
New TCP connection 2: 200.200.200.10(50704) <-> 200.200.200.101(80)
1366693465.1451 (0.0010)  C>S
Accept: */*
Host: domain.com
