Hi, I am new to irules. Need help in writing an irule that does a simple URI re-direction to seperate Pools with NO default Pool on the VS and the F5 returns a default-http page guiding to the user to use the exact uri/wsdl page. Something like - /dev goes to Pool-dev /ct goes to Pool-ct /uat goes to Pool-uat and the response for the default-URL (without any uri) is returned by the F5 saying “for dev use /dev?wsdl and so on…”
Please advise?
Just to add, i am running 11.5.1 HF3 on the 5250v platform.
Maybe you can do like that:
set path [string tolower [lindex [split [HTTP::path] "/"] 1]]
switch -glob $path {
"dev" { pool pool-dev }
"ct" { pool pool-ct }
"uat" { pool pool-uat }
default {
HTTP::respond 200 content "Content-Type "text/html" Connection Close"
You can get an iFile or base64 variable content to present the html too. Find some examples in this channel.
Regards.
thanks, can you please shed some light on this irule? what does set path, string tolower, lindex, split, switch -glob variables do?
You can find a good documentation of iRule events tips and tricks in this link: DevCentral
I will try to be clear, here we go:
This event triggers in http request
this will store the first http path segment in lower case
so, we'll define the request traffic direction as needed
example:
request for url: http://mywebservice.com/DEV/service
[HTTP::host] ==> mywebservice.com (not used, just to understand)
[HTTP::path] ==> /DEV/service
[split [HTTP::path] "/"] ==> [split /DEV/service "/"] ==> { DEV service}
[lindex { DEV service} 1] ==> DEV
[string tolower {DEV}] ==> dev (this is useful when web service is case insensitive (windows eg))
set path ==> stores the value "dev"
this will verify the value stored in path variable
case value is "dev", request goes to the pool-dev
case value is "ct", request goes to the pool-ct
case value is "uat", request goes to the pool-uat
otherwise, show the help page
default {
here we will write the response content page
HTTP::respond 200 content "`Available resource options````
