iRule for subdomain datagroup matching
I have been trying to find a solution to my requirement below,
We have subdomains like subdomain.domain.com and we want to perform a match on the domain part in a data group to return a pool and ideally an SSL profile.
For the pool part I think it should go something like this;
    set DATA_GROUP_HTTPSPOOL $::DG-HTTPSPool
    set HOST [string tolower [HTTP::host]]
    set POOL [ findclass $HOST $DATA_GROUP_HTTPSPOOL " " ]
    if { $POOL ne "" } {
       pool $POOL
This would be with a datagroup as follows;
ltm data-group internal /Common/DG-HTTPSPool {
    records {
        domain.com {
        data "pool-domain.com"
    type string
I don’t know how close this is to being correct or if what I’m trying to do is even possible. So any advice would be gratefully received.
I think i really need to use an
match ending_with
rather than the
findclass
but I’m not sure. Also i don’t know the best way to do the profile would it also sit under the when
HTTP_REQUEST
Many thanks,
Allan
Hi Allan,
which TMOS version are you running on? I’m asking because the
[findclass]
command and the way you’re referencing the data-group (aka. via
$::datagroup
) is deprecated since may years and would harm CMP-operations on current TMOS versions.
If you’ve loaded a TMOS version v10 or higher on your box, then the take a look to the iRule below. It uses the CMP-friendly
[class]
syntax to lookup the data-group containing the domain-to-pool information.
ltm data-group internal DG-HTTPSPool {
    records {
        "domain.com" {
        "domain.net" {
            data "pool-domain.net"
    type string
    if { [set pool [class match -value [domain [string tolower [getfield [HTTP::host] ":" 1]] 2] equals "DG-HTTPSPool"]] ne "" } then {
        pool $pool
        HTTP::respond 403 content "Access denied - Invalid HOST-name requested" "Content-Type" "text/html"
Cheers, Kai
Hi and welcome to the forum!
I understood the question a bit differently and thought you wanted to choose pool based on “domain.com” if the request was for ";.
This should do it in that case. Haven’t tested it for syntax though.
    set [domain [getfield [HTTP::host] ":" 1] 2]
    if { [class match $domain eq yourdatagrouplist] }{
        pool [class lookup $domain yourdatagrouplist]
        pool yourdefaultpool
As for the SSL profile you should probably look into SNI:
Hope that helped.
/Patrik
