Is SSL offloading possible using iRule, instead of using client ssl profile. Need F5 to provide cert to client using iRule.
In short, no. You can use an iRule to select among client SSL profiles, and even change some of the settings in the profile, but the profile itself is more than just which server certificate it sends.
