bsb
June 12, 2018, 5:44am
1
Team, would like to configure an irule to redirect based on client ip’s.
when HTTP_REQUEST { if { [matchclass [IP::client_addr] equals 1.1.1.0/24] } { do nothing. } elseif {([class match [IP::client_addr] equals 2.2.2.0/24]) }{ HTTP::redirect "; } }
It doesn’t work, is there a modification required.
First of create your DataGroup then use this irule:
when CLIENT_ACCEPTED {
if { not ( [class match [IP::client_addr] equals my_ip_dg] ) } {
do nothing
} elseif {([class match [IP::client_addr] equals my_ip_dg]) }{
HTTP::redirect "https://www.test.com"
Regards
If you do not want to create a data group, you can try the below one:
if { [IP::addr [IP::client_addr] equals 1.1.1.0/24] } {
do nothing
} elseif { [IP::addr [IP::client_addr] equals 2.2.2.0/24] } {
HTTP::redirect "https://www.test.com";
oguzy
June 12, 2018, 7:36am
4
do nothing
bsb
June 12, 2018, 9:23am
5
Missed one part, LTM is behind proxy which hides the incoming client ip, tried below option, still didn’t work.
i am trying to access the site from 2.2.2.x network and instead of redirect, posting a custom message
when HTTP_REQUEST { HTTP::header insert X-Forwarded-For [IP::remote_addr] if { [IP::addr [IP::client_addr] equals 1.1.1.0/24] } { do nothing } elseif { [IP::addr [IP::remote_addr] equals 2.2.2.0/24] } { HTTP::respond 503 content {
bsb
6
bsb
June 12, 2018, 9:25am
7
below content were removed.
< html> < head>< title> regret message < /title>< /head> < /html>
bsb
8
oguzy
June 12, 2018, 10:54am
9
HTTP::header insert X-Forwarded-For [IP::client_addr]
if { [IP::addr [HTTP::header X-Forwarded-For] equals 1.1.1.0/24] } {
do nothing
} elseif { [IP::addr [HTTP::header X-Forwarded-For] equals 2.2.2.0/24] } {
HTTP::respond 503 content "Page is currently unavailable."
event disable
TCP::close
If it does not work again, please share any errors if exist in the /var/log/ltm or try to logging for debug.
do nothing
event disable
TCP::close
bsb
June 12, 2018, 2:57pm
11
Hi, page is accessible on both subnets, no errors on tcpdump as well. tried to log under authorized subnet 1.1.1.0/24, it doesn’t update the logs.
when HTTP_REQUEST { HTTP::header insert X-Forwarded-For [IP::client_addr] if { [IP::addr [HTTP::header X-Forwarded-For] equals 1.1.1.0/24] } { log local0. “authsubnet”:[IP::client_addr]
bsb
12
Would you mind logging the X-Forwarded-For in HTTP request and checking IP address whether it matches to if condition or not?
log local0. “X-Forwarded-For: [HTTP::header X-Forwarded-For]”
oguzy
June 13, 2018, 7:56am
14
