So I have an iRule that identifies if the LB server pool is equal to 0 then call a different pool which is the server hosting the Sorry Page. The issue is the Sorry page is not at the root of this pool, its at /mov. Anyone know how I can modify my iRule so that when LB equals 0 it would direct traffic to the new pool/mov?
The reason I am calling a pool is because we are required to maintain the URL’s domain, so a redirect doesn’t work.
when HTTP_REQUEST { if { [active_members [LB::server pool]] == 0 } { pool mov_maintenance_page} { return }
Untested:
HTTP::uri /mov
} { return }
I would use the LB_FAILED event instead. Also, I might insert a connection close to make sure that the user gets a new iRule flow upon any retry:
when LB_FAILED {
set failed 1
HTTP::uri "/maintenance/maintenance.html"
when HTTP_RESPONSE {
if { [info exists failed] && $failed== 1 } {
HTTP::close
/Patrik
Hi again!
Here’s some comments:
when LB_FAILED {
LB failed is triggered when the load balancer
is unable to choose a member for the connection (no available
members, or too many retries due to server connection issues
Set the variable failed to 1 so we can check it later in the response
set failed 1
Rewrite the uri to whatever you want it to be.
The client would still see whatever they had from before
Select the pool you want to serve the maintenance page
Check if the LB failed event has been triggered by checking if
the variable failed exists and is set to 1
if { [info exists failed] && $failed == 1 } {
Close the connection to make sure that the user makes a new connection
HTTP::close
The problem with this setup, which I might mention too, is that you would be unable to send any pictures with the sorry page, unless you encode them with base64 within the html content OR use a CDN to deliver them.
Reason:
ol
Instead you might want to qualify incoming requests for the sorry page content directory before rewriting the uri:
` when LB_FAILED {
set failed 1
If the client does not request resources in the maintenance
folder, then rewrite the uri. Otherwise, let it pass through as the
content reqests belongs to the maintenance page
if { !([HTTP::uri starts_with "/mov") } {
HTTP::uri "/mov"
HTTP::close
From a design perspective I would consider delivering the sorry page content directly from the F5 though using HTTP::respond and content from the CDN, because when there's a server side problem, there's also a risk that your sorry pool members is affected too.
/Patrik
Silly me. Freestyling iRules is not working out so good it seems. Try this?
when LB_FAILED {
set failed 1
if { !([HTTP::uri starts_with "/maintenance/") } {
HTTP::close
/Patrik
About the question on how to host the page on the f5, there’s ton’s of articles on how to do that on DC. These should send you down the right track:
Here’s the article about HTTP respond:
Here’s a few examples:
You can manually trigger LB_FAILED by creating a pool with mock members, or disable all members in a pool and then test it out.
You can always write back if you run into trouble.
/Patrik
