This is expected behaviour, as there are 2 matches for HTTP::respond event when server goes down during the scheduled maintenance. This will cause TCL error with multiple redirects and cause reset (RST) to the connection. You can combine both iRules in one and give SORRY page only when server is down out of maintenace window.
set maintenance 1
set maintenance_start_time "0000";
set maintenance_end_time "2359";
set maintenance_day "Sunday";
scan [clock format [clock seconds] -format {%A %k %M}] {%s %s %s} cur_day cur_hour cur_minute
set cur_time ${cur_hour}${cur_minute}
if { ($cur_day eq $maintenance_day) &&
($cur_time >= $maintenance_start_time) &&
($cur_time <= $maintenance_end_time) } {
set maintenance 0
HTTP::respond 200 ifile "/Common/maintenance.html"
return
when LB_FAILED {
if { ([active_members Pool_A] < 1) and ($maintenance == 0) } {
#log local0. "scheduled maintenance going on. no sorry page"
HTTP::respond 200 ifile "/Common/sorry.html"
I thought of another idea of using event disable command to stop executing other iRules if maintenance page iRule is triggered. Use higher priority for sorry page iRule or move it to the top.
when HTTP_REQUEST priority 100 {
event disable all
