iRule for SMPT allowed - moved from 10.2.3 to 12.2
Existing iRule on 10.2.3 does not work on 12.2. Is there a sytax difference from 1.2.3 to 12.2
Called Data Group List: smtp_relay_allowed is in place
Snat Pool List: snat_smtp_relay is in place calling 10.40.1.199
iRule: smtp_relay_rule :
when CLIENT_ACCEPTED { set accepted_snat “10.40.1.199”
if { [ class exists smtp_relay_allowed ] } { if { [class match [IP::client_addr] equals $::smtp_relay_allowed] } { snat $accepted_snat
} else { snat automap } } else { snat automap } }
More readable format:
  set accepted_snat "10.40.1.199"
      snat $accepted_snat
      snat automap
    snat automap
It looks like if nothing else, the way you are referring to your datagroup in the class match statement will cause a runtime error and result in a RST being sent.
From the class page in the wiki:
“In v11, using $::datagroup_name will result in a TCL runtime error and a reset being sent to the client!”
This was resolved by removing character that were depreciated in 11.0
It is explained here: DevCentral - An F5 Technical Community
I removed the $:: from the reference to the data group. The global variable reference was deprecated in version 11.
Was: if { [class match [IP::client_addr] equals $::smtp_relay_allowed] }
Now: if { [class match [IP::client_addr] equals smtp_relay_allowed] }
