irule for selecting the same pool for multiple vips
I have two virtual servers ans both are pointing to same single server (pool member) with same port like 10.10.10.10:8888. so i need a irule to select the these pool member. please suggest. thank you
is match across for persistence usable?
sol5837: Match Across options for session persistence
yes i am having source persistence. i can use “Match Across Pools” but i dont want to differentiate with URI like { [HTTP::uri] starts_with “/a”. i need if the connection hitting vip it should point to the irule pool and same to another vip should point the same irule pool
you mean example in sol5837, don’t you? it is just an example (you do not need it).
ok.. can i have some thing like this when CLIENT_ACCEPTED { set DEFAULT_POOL [LB::server pool] }
i think you do not need irule at all. just persistence profile with match across option could be enough.
yes nitass its good. we no need to go for irule. suggested as create pool for individual vip and mention the pool member. its like below vip name : atm.aaa.com-80-vip vip IP : 20.20.20.20:80 pool : atm_pool member : 10.10.10.10:8888 vip name : atm.aaa.com-8888-vip vip IP : 20.20.20.20:8888 pool : atm_pool member : 10.10.10.10:8888
