We have an iRule configured on VS in F5. It reads for a particular strings and then redirects the traffic to a different pool based on string value. When I implement the same irule on another F5 device with new VS . The redirection is not working. Can any one please help to solve this issue . If there is any settings that I need to change on VS or SSL profile.
Thanks in advance
Can you post the VS config that the iRule isn’t working on?
Hello Ryan The only difference I see between them is there is server side SSL enabled / configured on the new F5 VS.
Are you terminating SSL on the F5 ? Client side SSL has to be configured for the F5 to be able to read the encrypted SSL traffic.
