Hello ,
I want to redirect URI based on the URI string as mentioned below .
Can someone please help me to write the irule for below requirements
Not Transformed: ORIGINAL URL: This will pass through unchanged:
SHOULD BE TRANSFORMED TO:
Regards, Muthu
try this local traffic policy (version 11.4.0 and above) instead of irule:
ltm policy Pol_eysso {
controls { forwarding }
requires { http }
rules {
DeepLinkKey {
actions {
0 {
http-uri
replace
path /eygsso/sso_login.aspx
conditions {
0 {
http-uri
path
values { /eysso/sso_login.aspx }
1 {
http-uri
query-parameter
name DeepLinkKey
values { - }
ordinal 1
strategy first-match
to install it, execute in tmsh load sys config merge from terminal and paste the code.
you can then enable it in virtual server.
the - character is not the good filter…
replace the policy by:
requires { http }
rules {
DeepLinkKey {
actions {
0 {
http-uri
replace
conditions {
0 {
http-uri
path
1 {
http-uri
query-parameter
name DeepLinkKey
contains
values { 0 1 2 3 4 5 6 7 8 9 }
ordinal 1
