Irule for pool selection base on cookie presence
Hello,
I wish to do pool selection base on cookie presence.
The logic is simple, if any http request come with a specific cookie ( like JSESSIONID) it need to go to a pool, otherwise it need to go to another pool.
Any help be appreciated.
Regards, Kannan.
  if {[HTTP::cookie exists {JSESSIONID}]} {
    pool mypool
If you are looking to choose a pool juts on the presence of a cookie this should do the trick. It will require an HTTP profile. If your app is HTTPS it will also require a client SSL profile:
    if {[HTTP::cookie exists "JSESSIONID"]}{
        pool poolA
    else {
        pool poolB
