iRule for pool member reselect
Hello F5Admins,
We are using LTM 11.3.0. One of our website running in IIS has lot of Application pools and whenever any of these pools goes down returns 503 http response code. Our requirement is whenever a response code of 503 occurs due to App pool failures, LB should route such request to the next available pool member without marking that pool member offline (since marking down will affect connections in other app pools). Though we are able to reselect a new pool member with this irule, it works only if the pool member is marked down.
when HTTP_REQUEST { set my_host_header [HTTP::host] set my_uri_header [HTTP::uri] }
when HTTP_RESPONSE { if { [HTTP::status] contains “503”} { catch { LB::down } HTTP::redirect “https://$my_host_header$my_uri_header” } }
Any idea how to achieve this without the “LB:Down” statement. Any help on this will be highly appreciated.
Thanks Sathish
Hi Santhish,
You could do something like the following
when LB_FAILED {
         LB::reselect pool
I hope this helps
-=Bhattman=-
Hi Bhattman
Thanks for your reply. I had tried this but unfortunately the LB_FAILED event gets triggered only when the server/IP address entirely goes down. This doesn’t work for IIS AppPool failures
Thanks Sathish
