iRule for missing or blank headers (user-agent and accept)
Hi all, I’m working on another iRule creation. I need to create a rule that will detect if the request headers for user-agent and/or accept is blank/missing. I also need to be able to exclude uri extensions with rss and smil. Below is the iRule I tried to create based on the requirements. Can I get some help with reviewing the rule and letting me know where I’ve gone wrong please?
if {not ([HTTP::uri] ends_with "rss") and not ([HTTP::uri] ends_with "smil")}
            log local0. "URI extension is not rss or smil."
        elseif { [HTTP::header "User-Agent"] eq "false" }
                 log local0. "User-Agent header is missing."
         elseif { [HTTP::header "Accept"] eq "false" }
                  log local0. "Accept header is missing."
         elseif { [HTTP::header "User-Agent"] contains "^$" }
                  log local0. "User-Agent header is blank."
         elseif { [HTTP::header "Accept"] contains "^$" }
                  log local0. "Accept header is blank."
If you want to check if a header exists you can use the following if {[HTTP::header exists User-Agent ]}{
You are checking is the value of User-Agent is False not that it does not exist
It’s slightly less specific but this should work (note the HTTP::header command will return null if the header doesn’t exist or if the header’s value is null);
if { [HTTP::uri] ends_with "rss" or [HTTP::uri] ends_with "smil" } {
 log local0. "URI extension is rss or smil."
 Optionally drop the traffic
 reject
 Stop executing the irule
 return }
elseif { [HTTP::header "User-Agent"] eq "" } {
 log local0. "User-Agent header is missing or blank." }
elseif { [HTTP::header "Accept"] eq "" } {
 log local0. "Accept header is missing or blank." }
Ok. Thank you verymuch!!!
