iRule for matching host & multiple uri's and close connection on the rest.
I’ve a got a question related to setting up a reverse proxy iRule with multiple sites and have to filter also on certain uri’s. we also offloading our ssl traffic at this moment.
the reverse proxy iRule already exists for other sites.
our setup is like this: for the complete iRule:
if { [string tolower [HTTP::host]] contains "site1.domain.com" } {
    SSL::disable serverside
    pool pool_poolxxx
    return
if { [string tolower [HTTP::host]] contains "site2.domain2.com" } {
    pool pool_poolyyy
    return
if { [string tolower [HTTP::host]] contains "site3.domain3.com" } {
    pool pool_poolzzz
    return
"Insert new code here" see examples below
the new url has to be checked on different uri’s and block all de rest including base url “newsite.domain.com”
complete has to be like: http host = newsite.domain.com and uri has to be check on this string “/ps/xyz/abc/123/y/” including wildcards.
Also on the same site also the uri /css has to be allowed aswel to load the css in the background.
I’ve tried things like
"insert code here 1 "
if { [string tolower [HTTP::host]] contains "newsite.domain.com" and [HTTP::uri] starts_with "/css" } {
            pool pool_poolxyz
            return
if { [string tolower [HTTP::host]] contains "newsite.domain.com" } {
    if { [HTTP::uri] starts_with "/ps" } {
        if { [HTTP::uri contains "/xyz/abc/123/y/" } {
            pool pool_poolxyz
            return
        else {
            HTTP::respond 404 "Not Found" "Connection" "close"
            return
"insert code here 2 "
if { [string tolower [HTTP::host]] contains "recruitment.provant.be" } {
    switch -glob [string tolower [HTTP::path]] {
        "*/ps*/xyz/abc/123/y/*" {
        pool pool_poolxyz
        return
    default {
        return
Any other ideas or solution?
Code 1 has some missing parts :
    pool pool_poolxyz
    return
        if { [HTTP::uri] contains "/xyz/abc/123/y/" } {
            pool pool_poolxyz
            return
            HTTP::respond 404 content "Not Found" noserver "Connection" "close"
            return
