Hello,
i want to create a irule for lowercase string for a specific url. Below is the irule which i am trying but i am not getting the result.The current version on client side is v11.3 .
when HTTP_REQUEST { if {[string match {[A-Z] } [HTTP::uri] eq “myBlock.Profile.com/Pages ”]}{ HTTP::redirect “http://[HTTP::host][string tolower [HTTP::uri]]” } }
Thank you.
nathe
August 1, 2014, 1:34pm
2
How about this?
if {[string match {[A-Z]} [HTTP::uri] eq "myBlock.Profile.com/Pages"]}{
set uri [string tolower [HTTP::uri]]
HTTP::redirect "http://[HTTP::host]$uri"
Rgds
N
hoolio
August 1, 2014, 1:50pm
3
What are you trying to match with the first URI check? This expression doesn’t make sense to me:
Also, you need to use wildcards in the string match to check for any capital letter:
% string match {[A-Z]} AAA
0
% string match {*[A-Z]*} AAA
1
So maybe something like this?
if {"[HTTP::host][HTTP::uri]" eq "myBlock.Profile.com/Pages"]}{
HTTP::redirect "myblock.profile.com/pages"
Aaron
Hii,
The above irules are not working properly… So i tried something like this way…
when HTTP_REQUEST { if {[HTTP::host] eq “abfluat.abfsg.com ”]}{ HTTP::redirect “http://[HTTP::host][string tolower [HTTP::path]]?[HTTP::query]” } }
But this also not working properly…
nathe
August 4, 2014, 8:54am
6
You’ve got an extra square brace on the 2nd line.
Also, http::path and http::query is, in effect, http::uri so why not try this?
if {[HTTP::host] eq "abfluat.abfsg.com"}{
Rgds Nathan
nitass
August 6, 2014, 2:52pm
7
what about this one?
config
root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm virtual bar
ltm virtual bar {
destination 172.28.24.10:0
ip-protocol tcp
mask 255.255.255.255
pool foo
profiles {
http { }
tcp { }
rules {
qux
source 0.0.0.0/0
source-address-translation {
type automap
translate-port disabled
vs-index 60
root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm rule qux
ltm rule qux {
when RULE_INIT {
set static::uri "/myBlock.Profile.com/Pages"
set static::uri_lower [string tolower $static::uri]
set uri [HTTP::uri]
set uri_lower [string tolower $uri]
if { $uri_lower eq $static::uri_lower } {
if { $uri ne $uri_lower } {
HTTP::redirect "http://[HTTP::host]$uri_lower"
test
[root@ve11a:Active:In Sync] config curl -I http://172.28.24.10/myBlock.Profile.com/Pages
HTTP/1.0 302 Found
Location: http://172.28.24.10/myblock.profile.com/pages
Server: BigIP
Connection: Keep-Alive
Content-Length: 0
[root@ve11a:Active:In Sync] config curl -I http://172.28.24.10/myblock.profile.com/pages
HTTP/1.1 404 Not Found
Date: Wed, 06 Aug 2014 14:38:41 GMT
Server: Apache/2.2.3 (CentOS)
Content-Type: text/html; charset=iso-8859-1
Hello Guys, thanks for all responses. I had come up with a irule which is working properly..
when HTTP_REQUEST { if { [HTTP::host] equals “www.joe.com ” and [HTTP::uri] starts_with “/net/myjoe” } { HTTP::redirect “http://[HTTP::host][string tolower [HTTP::uri]]” } }
