Hi All,
I require your help to write the iRule for limiting the client connection based to VIP on time base.
if any one knows or already written kindly share your inputs to me for achiving this.
Thanks a lot to you all in advance.
Regards,
Lingaraj R N
hello,
hope following links work for you
thanks
This is from Kevin Stewart and this thread: https://devcentral.f5.com/community/group/aft/2165776/asg/502273814. Hope it helps.
when RULE_INIT {
set static::not_before_time "10am today"
set static::not_after_time "5pm today"
if { ( [expr [clock seconds] < [clock scan $static::not_before_time]] ) or ( [expr [clock seconds] > [clock scan $static::not_after_time]] ) } {
HTTP::respond 200 content "After hours - access disabled" "Connection" "Close"
