irule for handling jpg, bmp request
we want to use other new pool or servers for handling static page request such as .jpg, bmp, mp3 etc.
and now we already had the following irule running:
when CLIENT_ACCEPTED {
set add_persist 1
when HTTP_RESPONSE {
if { [HTTP::cookie exists “JSESSIONID”] and $add_persist } {
persist add uie [HTTP::cookie “JSESSIONID”]
set add_persist 0
if { [HTTP::cookie exists “JSESSIONID”] } {
persist uie [HTTP::cookie “JSESSIONID”]
set jsess [findstr [HTTP::uri] “jsessionid” 11 “;”]
if { $jsess != “” } {
persist uie $jsess
anyone know if we want to pass static request to other servers/pool, what we can to modify?
Regards
Simon.
I’m assuming you don’t need persistence for the static files. If so, something like this should work (assuming you don’t care about persistence on the static requests…
  set add_persist 1
  if { [HTTP::cookie exists "JSESSIONID"] and $add_persist } {
    persist add uie [HTTP::cookie "JSESSIONID"]
    set add_persist 0
  switch -glob [string tolower [HTTP::uri]] {
    "*.jpg" -
    "*.bmp" -
    "*.mp3" {
      pool static_pool
    default {
      if { [HTTP::cookie exists "JSESSIONID"] } {
        persist uie [HTTP::cookie "JSESSIONID"]
        set jsess [findstr [HTTP::uri] "jsessionid" 11 ";"]
        if { $jsess != "" } {
          persist uie $jsess
Basically what this does is for all requests ending with “.jpg”, “.bmp”, or “.mp3”, assign the traffic to the static_pool. All other requests will default back to your original logic.
-Joe
