Issue:
Trying to bring up a parallel site for ONES main production site that goes live on Tuesday. Using an iRule for forcing https:
HTTP::redirect https://[HTTP::host][HTTP::uri]
The problem is that when a FORM SUBMIT comes in, the fields are all blank.
F5 Support response:
Here is a example from devcentral:
rule redirect_rule {
This rule should just issue a redirect for all traffic that goes to the port 80 virtual server should look like the following:
[HTTP::redirect “https://[HTTP::host][HTTP::uri]”]
This rule waits for the request after the client finishes the tcp handshake in order to fill in the host and uri information and then issues the redirect.
In order for the pool to work the virtual server must use the default or customer http profile for the HTTP Profile section in the Virtual Server. This allows the virtual server to parse the http information.
His BIGIP is at version 9.1 so he is not having to dealing with previous versions issues on this, but our example doesn’t currently
work for him. The parameters not coming thru. Mind you this is a form post.
Just to be clear on the problem:
We’ve confirmed that if a form does a POST ** to another web template ** and the F5 redirects it to “https” because the form ‘action’ explicitly says “http:” The end result is that all the FORM FIELDS are lost. They can’t just change the ‘http’ to https’ manually because most those calls come from other systems. How can that PAYLOAD be saved?
They need to be able to redirect http using the F5 to https without losing the form fields. If there is a better way to handle this other than the redirect, then me know. Otherwise, what needs change in this irule to get the rest of the data there:
Is more needed beyond the HTTP_REQUEST? The examples I see are for how to do things when you want to change the uri, not the protocol. Isn’t that why we are having to do the redirect?
