IRule for Exact resource access rejection
I would like to know the feasibility of implementing iRules for below scenario, kindly suggest whether it is achievable or not.
https://my.domain.com/mrj/home/srt/portal/prtroot/com.dev.net.sendemail >> only request to this resource should get rejected
https://my.domain.com/mrj/home/srt/portal/prtroot/\* >> other should get allowed
Hello NetWork.
Yes, it’s feasible. Try this:
	set uri [getfield [HTTP::uri] "?" 2]
	if { $uri ends_with "/mrj/home/srt/portal/prtroot/com.dev.net.sendemail" } { reject }
Regards,
Dario.
Hi Dario,
Thanks a lot for your response!
Below is our existing and working iRule:
if { [HTTP::uri] == “/” } { HTTP::redirect “http://[HTTP::host]/mrj” }
elseif { [string tolower [HTTP::uri]] starts_with “/mrj” or [string tolower [HTTP::uri]] starts_with “/web” or [string tolower [HTTP::uri]] starts_with “/htmlb” }
{ pool pool-A }
elseif { [string tolower [HTTP::uri]] starts_with “/abc” }
{ pool pool-B }
elseif { [string tolower [HTTP::uri]] starts_with “/” }
{reject}
If we modify it as below, will it work?
set uri [getfield [HTTP::uri] “?” 2]
elseif { $uri ends_with “/mrj/home/srt/portal/prtroot/com.dev.net.sendemail” }
{ reject }
{ pool pool-A }
{ pool pool-B }
{reject}
Also, can you please help to understand why we need to put “2” in set uri [getfield [HTTP::uri] “?” 2] ??
And, in case if we want to reject anything after sendemail i.e /mrj/home/srt/portal/prtroot/com.dev.net.sendemail*, how that can be achieved.
Hello NetWork.
Actually the previous sentence has a mistake. It should be like this.
set uri [getfield [HTTP::uri] "?" 1]
This is used to remove de Query parameter of the URI. For example if you receive something like this:
/mrj/home/srt/portal/prtroot/com.dev.net.sendemail?myuser=john
Taking into account that you need to reject any URI related with
Then you should use “starts_with” instead of “ends_with”, and the sentence before would not be necessary.
Your iRule should be like this:
	if { [HTTP::uri] == "/" } { HTTP::redirect "http://[HTTP::host]/mrj" }
	elseif { [string tolower [HTTP::uri]] starts_with "/mrj/home/srt/portal/prtroot/com.dev.net.sendemail" } { reject }
	elseif { [string tolower [HTTP::uri]] starts_with "/mrj" or [string tolower [HTTP::uri]] starts_with "/web" or [string tolower [HTTP::uri]] starts_with "/htmlb" } { pool pool-A }
	elseif { [string tolower [HTTP::uri]] starts_with "/abc" } { pool pool-B }
	elseif { [string tolower [HTTP::uri]] starts_with "/" } {reject}
Please, if this was helpful don’t forget to mark my answer as ‘the best’ to help me for the contribution.
Regards,
Dario.
Hi Dario,
We have tested in our customer environment, it works as expected.
Many thanks for your help!
