iRule for directing traffic from a specific host and URI to a given pool
Hi, Guys. I need help for writing an iRule to send traffic from host1.internet.com with a URI request matching /uri1* to a pool pool1 Thank you in advance.
use this irule.
                    if { [string tolower [HTTP::uri]] starts_with "/uri1*" } {
                         pool pool_X
Hi, Samir. This appers to be a straight URI redirect to a pool. I am looking to also match the source of the request to a specific host, host1.internet.com. Thank you for your help. Vadim.
try this…
  if { [string tolower [HTTP::host]] equals "host1.internet.com" } {
    if { [string tolower [HTTP::uri]] starts_with "/uri1" } {
      pool pool_X
if you are using version 11.4 or above, you can configure Local traffic policy instead of irule.
  • Policy
    • require http
    • controls forwarding
  • Rule 1 :
    • Condition
    • Action forward pool Pool_X
Arpydays, Entered your rule, and it passed F5 mustard. Will test in the morning but certainly makes sense and should work. Thank you very much.
Stanislas, I am running a BigIP version 10.2.4. Thank you as well.
Vadim.
Hope it will work.. try this. when HTTP_REQUEST { if { [string tolower [HTTP::host]] equals “host1.internet.com” and [string tolower [HTTP::host]] starts_with “/uri*” } { pool pool_x } }
in the irule, create a else statement with default pool assignment. if there is no default pool assignment, and the user browse first to /uri1 then to /uri2 in the same TCP connection, the second request will be assigned to the previous pool.
When CLIENT_ACCEPTED {
    set default_pool [LB::server pool]
      pool pool_X
    } else { pool $default_pool}
