I´m working with a client that is getting DD0s attacks from random IPs. We have some limitations with the Hardware as we only have an ASA and the F5 but no additional security modules, and no IPs for the FW. In the ASA I have limited the embryonic connections using TCP Intercept.
In the F5 i would like to write an irule to deny incoming connections containing the following string: UNION%20SELECT%20
During the attacks we were able to identify that all the IPs contain UNION%20SELECT%20 in the url. So I´m wondering if this could work:
/usr/libexec/bigpipe rule DDOs '{
if { [string tolower [HTTP::uri]] contains “UNION%20SELECT%20” } {
log local0. “Rejecting [HTTP::uri] request”
reject
1- I need this apply for all the VIPs, for all the incoming connections. 2. I know that we should have Security Modules or an IPs or NextGen Firewall, but unfortunatly we have limitations. 3. Any other suggestion is welcome, I really appreciate your help!
The one issue I see is that you have “UNION%20SELECT%20” as what you are searching for.
But you also have “stringtolower” which would change the URI to all lowercase, and therefore “UNION%20SELECT%20” would never actually show up since it is in CAPS.
Change that to “union%20select%20”
Hope that helps! If it does please up-vote and select this answer, it’d be greatly appreciated!
