irule for bandwidth alert or active connection alert
I’m hoping that someone can help me out with this. Is there a way to write an irule to send out a notification if we reach 10megs throughput? or 11k sessions? just a simple e-mail?
i know it shows up on the performance menu but it would be great to setup like a threshold or notification when it gets to a certain point.
Has anyone ever accomplished this? Or can help?
Phil
The only option I can think of for an iRule would be to keep track of sessions but even that would likely create a log message that you’d still have to leverage snmp or syslog to alert on.
I do similar monitoring but use SNMP polling to alert. Is that an option for you?
I’m not totally clear on the use case, but it sounds like you’re looking for a box-total style alert. If so, look here for starters:
-and for custom traps,
http://devcentral.f5.com/Default.aspx?tabid=63&articleType=ArticleView&articleId=256
If you’re looking for per-connection information you may consider the TCP::bandwidth command from an iRule.
-Matt
