Hi All, I need help in refining this irule.
if { ([HTTP::uri] contains "/recommended") or
([HTTP::uri] contains "/activate") or
([HTTP::uri] contains "/activated")or
([HTTP::uri] contains "/userStatus")or
([HTTP::uri] contains "/recByCat")or
([HTTP::uri] contains "/targeted") } {
HTTP::respond 403 content {403 Unauthorized}
What issues are you having with this iRule? What are you looking to refiine?
I’m trying to use switch -glob tolower for it, but cant figure out the syntaxes
Thanks in advance
You can use a switch statement, but it will look a little strange since you are doing the same thing for all cases. It would look something like this:
switch [string tolower [HTTP::uri]] {
"/recommended" { HTTP::respond 403 content {403 Unauthorized}
"/activate" { HTTP::respond 403 content {403 Unauthorized}
"/activated" { HTTP::respond 403 content {403 Unauthorized}
"/userStatus" { HTTP::respond 403 content {403 Unauthorized}
"/recByCat" { HTTP::respond 403 content {403 Unauthorized}
"/targeted" { HTTP::respond 403 content {403 Unauthorized}
DEJ
April 28, 2015, 8:58pm
5
Hello M,
The below is pretty much a template, depending on how you want the value to match within the URI. I’ve included the link to the switch section of the iRules wiki, a very good resource. The way I’m utilizing the wildcard would make these match URI when they begin with the value.
switch -glob [string tolower [HTTP::uri]] {
"/recommended*" -
"/activate*" -
"/activated*" -
"/userstatus*" -
"/recbycat*" -
"/targeted*" { HTTP::respond 403 content {403 Unauthorized}}
Hello M,
"/recommended*" -
"/activate*" -
"/activated*" -
"/userstatus*" -
"/recbycat*" -
This is a better solution than mine. I was unaware of the ability to put multiple options together like this.
Thanks sooo much for your help everyone!!!
