iRule Errors
Hello all.. Can you please take a look at the below iRule and see why the BIGIP is giving the below errors?
First step is to see if the HTTP requested Hostname ‘Exactly’ matches class vanityurls
This class file contains hostnames and specific http request strings as values
if { not ([string tolower [HTTP::host]] equals [www.hallmark.com||hallmark.com]) }
{ set vanityuri [class match -value [string tolower [HTTP::host]] equals vanityurls]
if {$vanityuri ne “”} {
HTTP::redirect 301 “$vanityuri”
unset vanityuri
else { HTTP::redirect 301 http://www.hallmark.com/~~http://www.hallmark.com/~~ }
Second step is to see if the HTTP requested ‘Exactly’ matches class queryurls
The query needs to be appended to the redirect
set queryyuri [class match -value [string tolower [HTTP::path]] equals queryurls]
if {$queryuri ne “”} {
HTTP::redirect 301 “$queryuri[HTTP::query]”
unset queryuri
Third step is to see if the HTTP requested URI ‘Exactly’ matches class exacturls
set exacturi [class match -value [string tolower [HTTP::path]] equals exacturls]
if {$exacturi ne “”} {
HTTP::redirect 301 “$exacturi”
unset exacturi
Fourth step is to see if the HTTP requested URI ‘Starts with’ class starturls
This step only gets executed if an ‘Exact’ Match and ‘Contains’ Match was not found
set starturi [class match -value [string tolower [HTTP::path]] starts_with startturls]
if {$starturi ne “”} {
HTTP::redirect 301 “$starturi”
unset startturi
Fifth step is to see if the HTTP requested URI ‘Contains’ matches class containsurls
This step only gets executed if an Exact Match was not found
set containturi [class match -value [string tolower [HTTP::path]] contains containurls]
if {$containuri ne “”} {
HTTP::redirect 301 “$containuri”
unset containuri
iRule error 01070151:3: Rule [SRD-Redirect] error:
line 6: [undefined procedure: www.hallmark.com||hallmark.com] [www.hallmark.com||hallmark.com] line 6: [missing a script after “if”] [ ]
line 7: [undefined procedure: set vanityuri [class match -value [string tolower [HTTP::host]] equals vanityurls] if {$vanityuri ne “”} { HTTP::redirect 301 “$vanityuri” unset vanityuri } else { HTTP::redirect 301 http://www.hallmark.com/ } ] [{ set vanityuri [class match -value [string tolower [HTTP::host]] equals vanityurls] if {$vanityuri ne “”} { HTTP::redirect 301 “$vanityuri” unset vanityuri } else { HTTP::redirect 301 http://www.hallmark.com/ } }]
line 16: [can’t find value_list] [class match -value [string tolower [HTTP::path]] equals queryurls]
line 18: [wrong args] [HTTP::redirect 301 “$queryuri[HTTP::query]”] line 22: [can’t find value_list] [class match -value [string tolower [HTTP::path]] equals exacturls]
line 24: [wrong
Thanks,
Jay.
1. square brackets, e.g. [www.hallmark.com||hallmark.com], evaluates of content as a command.
iRules Optimization 101 - 04 - Delimiters: Braces, Brackets, Quotes and more by Deb
2. HTTP::redirect uses 302. If you want 301, you have to use HTTP::respond instead.
HTTP::respond wiki
3. since local variable will be gone after closing connection, unset may be omitted.
can you try this irule?
[root@ve10:Active] config  b rule myrule list
rule myrule {
   set host [string tolower [HTTP::host]]
   if { not ($host equals "www.hallmark.com" or $host equals "hallmark.com") } {
      if {$vanityuri ne ""} {
         HTTP::respond 301 Location "$vanityuri"
         HTTP::respond 301 Location "http://www.hallmark.com/"
   if {$queryuri ne ""} {
      HTTP::respond 301 Location "$queryuri[HTTP::query]"
   if {$exacturi ne ""} {
      HTTP::respond 301 Location "$exacturi"
   if {$starturi ne ""} {
      HTTP::respond 301 Location "$starturi"
   if {$containuri ne ""} {
      HTTP::respond 301 Location "$containuri"
