All -
We just upgraded our F5 LTM to v14.1 from v11.6.3 successfully. However, now that we are running on v14.1, we are getting a lot of iRule errors in our LTM Logs.
I have edited the iRule names & paths of URLs & URIs for security purposes.
Any help with these iRule changes would be greatly appreciated.
Examples of the errors are:
TCL error: /Common/iRule_1 - ERR_NOT_SUPPORTED (line 2) invoked from within "HTTP::header "User-Agent""
The iRule has the following:
Rewrite the User-Agent header value if it's empty
if { [string length [HTTP::header "User-Agent"]] == 0 || not [HTTP::header exists "User-Agent"] }{
Replace the User-Agent header with a default value
HTTP::header replace "User-Agent" "Mozilla/4.0 (compatible; No User Agent Provided)"
Another Example error:
TCL error: /Common/redirect_irule - ERR_NOT_SUPPORTED (line 1) invoked from within "HTTP::uri"
TCL error: /Common/redirect_irule - ERR_NOT_SUPPORTED (line 7) invoked from within "HTTP::uri"
if { [HTTP::uri] equals "/portal/" or [HTTP::uri] equals "/"} {
if {[HTTP::host] starts_with "URL"}{
HTTP::redirect "http://www.URL.org/contact-us/contact-us.aspx"}
if {[HTTP::host] starts_with "path"}{
HTTP::redirect "http://www.anotherURL.com/Contact-Us/Contact-Us.aspx"}
if {[HTTP::host] starts_with "path1"}{
HTTP::redirect "http://www.anotherURL.com/applications/path1/contact-us.aspx"}
if {[HTTP::host] starts_with "path2"}{
HTTP::redirect "http://www.anotherURL.com/applications/path2/Contact-us.aspx"}
if {[HTTP::host] starts_with "path3"}{
HTTP::redirect "http://www.anthoerURL.com/applications/path3/contact-us.aspx"}
For us a solution has been to add “elseif” or “return” statements to each iRule that has a issue. So far the change to add the “elseif” between each “if” statement appears to now work properly.
Hopefully if someone else has this same issue when upgrading their F5 to v14.1+ this will help them.
if {[HTTP::has_responded]} {return}
if { [string length [HTTP::header "User-Agent"]] == 0 || not [HTTP::header exists "User- Agent"] }{
or
`when HTTP_REQUEST {
elseif {[HTTP::host] starts_with "path"}{
elseif {[HTTP::host] starts_with "path1"}{
elseif {[HTTP::host] starts_with "path2"}{
elseif {[HTTP::host] starts_with "path3"}{
Your first iRule is the
HTTP::header
command think you need to include the key word
value
in 14.
if {([string length [HTTP::header value "User-Agent"]] == 0) || !([HTTP::header exists "User-Agent"])}{
With your second iRule looks ok other than the formatting and the perfect use case for using
switch
, give the following a try and see if this fixes the errors:
if {([HTTP::uri] eq "/portal/") || ([HTTP::uri] eq "/")} {
switch -glob [HTTP::host] {
"URL*" {HTTP::redirect "http://www.URL.org/contact-us/contact-us.aspx"}
"path1*" {HTTP::redirect "http://www.anotherURL.com/applications/path1/contact-us.aspx"}
"path2*" {HTTP::redirect "http://www.anotherURL.com/applications/path2/contact-us.aspx"}
"path3*" {HTTP::redirect "http://www.anotherURL.com/applications/path3/contact-us.aspx"}
"path*" {HTTP::redirect "http://www.anotherURL.com/Contact-Us/Contact-Us.aspx"}
I had a similar issue on 14.1. I’ve figured out what behaviour has changed and what can be done to work around this.
My virtual server has two iRules, the 1st iRule has some header cleansing logic using “HTTP::header replace” this iRule has higher priority, it runs first. My second irule had some logic that sometimes triggers a HTTP response, similar to what you have above. HTTP::redirect triggers a HTTP response so the issue is probably the same.
It appears that you can no longer modify HTTP request headers if you trigger a response at the F5. You need to rejig your code so that “HTTP::header replace” only occurs after any possible HTTP responses have been triggered (and these should be followed by a “return” to stop processing the request).
Ignore me, I just realised the second iRule had no “priority”, so it was actually occuring before the 1st iRule. Added the priority and that fixed it.
