IRule error in routing traffic
Hello Gentlemen,
I would like to see if you can help me on an error appears in the following iRule:
when CLIENT_ACCEPTED {
if { [IP::addr[IP::client_addr]] equals 10.2.10.0/23 } {
if { [LB::status pool pool_citrix member 10.1.2.143 80] eq “down” } {
pool pool_citrix2
pool pool_citrix2
The error shown is as follows:
01070151:3: Rule [/ Common / Teste_Citrix] error:
line 2: [parse error: syntax PARSE 68 {syntax error in expression “[IP: addr [IP :: client_addr]] equals 10.2.10.0/23”: extra tokens at end of expression}] [{[IP :: addr [IP: client_addr]] equals 10.2.10.0/23}]
The goal is that this iRule forwards all traffic from network 10.2.10.0/23 to the pool_citrix2.
Thanks for your help.
Best regards,
Raoni
can you try this?
to:
if { [IP::addr[IP::client_addr] equals 10.2.10.0/23] } {
Thank you, now gave no error.
Best regards
Hello
The iRule not had any further problems in its creation, however it did not show the expected result.
With that, I would like to request a new help for it to go to work.
The purpose of the iRule is that when a host tries to access the network 10.2.10.0/23 pool_citrix, it is forwarded to the member pool 10.1.2.143.
The rest should go to the pool_citrix2 which includes the other members.
With this in VS as I put the pool default pool_citrix and add the iRule created right?
i think your irule looks okay. can you add some logging to the irule?
e.g.
when SERVER_CONNECTED {
        log local0. "[IP::client_addr]:[TCP::client_port] -> [clientside {IP::local_addr}]:[clientside {TCP::local_port}] -> [IP::remote_addr]:[TCP::remote_port]"
