iRule equals not matching similar keys in datagroup
Hi!
So we have an iRule which matches the URI against a datagroup via equals, nothing out of the ordinary:
    set matchedEquals [class match -value [string tolower [HTTP::uri]] equals dg_list]
    if {$matchedEquals ne ""} {
        HTTP::respond 301 Location "$matchedEquals"
        unset matchedEquals
We recently had a case where there are 2 similar URI’s in the datagroup:
  1. /api :=
  2. /api/demo :=
We find that the iRule is able to match /api, but is unable to match for /api/demo. From what I understand, the equals operator would match the longest key, so not exactly sure why it is failing to match.
Any help would be much appreciated. Thanks in advance!
Hi Nicholas,
strange behaviour can you replace equals by “==”
and log URI:
log local0. “URI: [string tolower [HTTP::uri]]” to be sure that you math “/api/demo”
regards
