Bug ID 753925 (always use the F5 bug tracker to check for know bugs)?
To be certain that it is a bug add simple log local0. after " CLIENTSSL_CLIENTCERT { " and before " if { [SSL::cert 0] eq “” } { " also add loh local0. right after " if { [SSL::cert 0] eq “” } { ". Maybe also add log local0. right after " else { " and before " if {not([X509::not_valid_before [SSL::cert 0]] contains “2021”)} { "
This way you will se to where the irule is triggered before it stops working.
