I have no answer, but I would comment out the debug statements and see if that makes a difference. The idea is that whatever is loaded in memory should not have it active it if remove it.
I’d guess it’s because there is another iRule which sets a global variable named debug to 1. If you change this iRule from ::debug to ::single_vs_debug, you should be able to avoid the problem.
I’ve updated the Codeshare example’s logging to do this and add the client IP:port to the log statements.
Strange, I didn’t find such another rule, but thanks for the suggestion, I’ll try it at tomorrow.
I taught (didn’t check syslog before) that maybe 9.4.7 did that, as just upgraded from 9.4.6 to 9.4.7.
BTW, right now I copy&pasted identical iRules for multiple virtual server, but what is the best practice for using one iRule for multiple virtual server?
Edit, reverted to 9.4.6 anyway, as virtual server with client and server certificate inside forwarded about hundred connections after real user’s browser one connection and target application went mad.
9.4.6 does work well. Anyone else noticed such bug?
If you want to use the exact same iRule for multiple virtual servers you should reference the same iRule. If you need to make changes to the iRule and have different versions of the same iRule saved on the same LTM unit, you should rename all of the variables to be unique to that iRule. It’s something of a nuisance, but necessary to avoid trampling of variables between iRules.
If you still see non-iRule issues after upgrading again to 9.4.7, you should open a case with F5 Support.
Well, after downgrading to 9.4.6 no such running debug logs as in 9.4.7 using same rules.
So seems something is changed in 9.4.7 (however I didn’t find any info from changelog) on this is a bug.
I’ll try to upgrade only one node to 9.4.7 and change the rule in that node and check the logs. But seems with Aaron -s suggest I can shut down these logs, but I have no idea how disable this flooding issue.
