iRule data group
Hi
We have some iRule data groups need to be updated regularly and the iRule will forward the traffic to different servers base on them. In order to minimize the work load, are there any ways we can update the data group quickly, say we have a excel/xml IP list file which exported from monitoring system, can we import it to F5 data group configuration? Any other ideas?
Thanks.
Joe wrote an article on the File Transfer APIs that shows how to use the file upload/download APIs in the System.ConfigSync interface.
iControl 101 - 06 - File Transfer APIs
Hi Stuart, We don’t have iControl, any other work around? Thanks.
Updating a data group is relatively straight forward. The hard part I think is going to be the conversion process. There’s no tool that I’m aware of to convert from Excel spreadsheet or flat XML file to data group format. Is it simply a single list of IP addresses, different lists of IP addresses, or is it a list of key-value pairs?
I don’t think SNMP is the way to go. In lieu of iControl (probably the best way), you could partially automate the process by first uploading the flat list of IP addresses. Example:
10.70.0.1/32
10.70.0.2/32
10.70.0.3/32
10.70.0.4/32
10.70.0.5/32
10.70.0.6/32
10.70.0.7/32
10.70.0.8/32
10.70.0.9/32
And then processing this file with a simple Bash script:
!/bin/bash
data_group=dgimport_ip_list
import_file=iplist
 import the first line and replace everything in the data group
line=`head -1 $import_file`
tmsh modify ltm data-group internal $data_group records replace-all-with { $line }
 parse the rest of the file and add the data to the data group
sed 1d $import_file |while read line
do
    tmsh modify ltm data-group internal $data_group records add { $line }
done
Make sure the address-based data group has been created first.
iControl comes free, or you can use scp to upload your data
