I am attempting to write an iRule that checks a cookie on HTTP_REQUEST and then writes a cookie on HTTP_RESPONSE in order to control the display of a banner message:
when CLIENT_ACCEPTED {
set ckname NotificationDone
set ckvalue 1
set ckdomain .[HTTP::host]
when RULE_INIT {
set static::notification_page {
... HTML Notification Page - code omitted ... }
if { (not [HTTP::cookie exists NotificationDone]) } {
HTTP::respond 200 content [subst $static::notification_page] Mime-Type "text/html"
when HTTP_RESPONSE {
HTTP::cookie insert name $ckname value $ckvalue path / domain $ckdomain
HTTP::cookie expires $ckname 120
When I run this code I get: “[command is not valid in the current event context(CLIENT_ACCEPTED)][HTTP::host]” I also get an similar error in the HTTP_RESPONSE when I attempt to set the cookie.
I’ve seen a number of examples that use this same pattern so I’m not sure what I am missing. Any help would be greatly appreciated.
Kevin
