iRule CMD usage clarification - SSL::SNI
I’m looking for an iRule command to extract the Server Name attribute (SNI) from an incoming SSL/TLS Client Hello packet.
According to the F5 description:
[F5 Cloud Docs ]
The [SSL::SNI] cmd returns the “Server Name” attribute of the SSL Profile currently selected - which is fine if there are multiple SSL profiles attached to the VS.
However for my application, I would like to extract the incoming Server Name from the Client Hello packet.
Would [HTTP::host] work instead?
Thanking you
Cheers
Drew
Hi
[HTTP::host] will just return the Host Header. If you want SSL info, try playing around with SSL::extensions.
I wish I could fine a minute to get you the right iRule, but not sure I will have the time :slight_smile:
Yonan
​Here it goes…
when CLIENTSSL_HANDSHAKE {
    log local0.info "CLIENTSSL_HANDSHAKE"
    set ext_exists [SSL::extensions exists -type 0]
    log local0.info "SSL extension type 0 exists: $ext_exists"
    if {$ext_exists} {
        set scan [binary scan [SSL::extensions -type 0] S1S1A4A* ext_type ext_len disc ext]
        #set sni_hostname [binary format H* $ext]
		log local0. "SSL server_name $ext"
Hi Yoann
Firstly my apologies for the late reply (have been away)
I’ll test it hopefully this week.
Thanking you
