IRule causes Virtual Servers to be "up"?
Hi Everyone,
When I replace the first iRule below with the second iRule belown on a virtual server the VS is marked up when the server pool has no available members? Any idea what might be going on here?
First iRule
   set uri [string tolower [HTTP::uri]]
   if {$uri starts_with "/services"}
   else
    HTTP::redirect https://[HTTP::host][HTTP::uri]
Replacement iRule
 if { [string tolower [HTTP::uri]] starts_with "/services" } {
 pool ws_server_pool
 elseif { [string tolower [HTTP::uri]] equals "/public/diagnostic.do"}
 pool gs_server_pool
 else {
Thanks!
Paul
I believe that the virtual will inherit any monitoring state of a pool referenced in an iRule. Your previous rule didn’t contain a pool - thus it had no monitoring associated with it. Your new rule references 2 pools. It would only take 1 pool member among both pools to make the virtual “up”. You can test this by marking all pools down and looking at the corresponding virtual status. I seem to also remember that if there are no monitors on the pools referenced within the irule - then the virtual where that irule applied with always be up. I’d personally love some confirmation on that, but that is at least the behavior that I’ve observed.
i confirm what wolfpack said. Status of pool within the iRule will impact the VS status.
Yeah, i verified that taking down the nodes in the pools that are referenced in the iRule does change the status of the VS.
Is this good behavior?
I would expect the primary pool as a resource of the VS to be the determining factor for the VS being up/down or the requirement that all referenced pools in the iRules have to be available for the VS to be available, not just one pool.
I have verified that a GTM which monitors the LTM still sees the servers as unavailable even though the LTM has the VSs marked as up.
Thanks for the replies
-Paul
I have found a “trick” to get around this behavior. If you set the pool name as a variable and then call the variable in the pool statement, the iRule doesn’t seem to “know” about status anymore. I had a similar problem with this rule:
  If the QA cookie exists, go to the QA pool.
 if { [HTTP::cookie exists "QAPilot"] } {
 pool WWW-QA
 else
 pool WWW-GLOB
 when LB_FAILED {
     LB::reselect pool WWW-GLOB
However, we needed the VS to fail if WWW-GLOB was down, even if WWW-QA was up (due to OSPF route advertisement). Doing this fixed the problem (since WWW-GLOB was set as the default pool, if the “if” doesn’t fire it will fall out to that):
 set lb_pool "WWW-QA"
 else
 set lb_pool "WWW-GLOB"
 pool $lb_pool
  If load balancing fails to the QA pool, load balance to the PROD pool.
 when LB_FAILED {
Denny
