IRule and Error Checking
Please See comments below
if { [HTTP::uri] starts_with “/channel/” } {
pool QA1
elseif {[HTTP::uri] starts_with “/performance/” } {
pool QA2
elseif { [HTTP::uri] starts_with “/lead/” } {
pool QA3
Please review the irule
I want the user to end the URI with /. If this is not done, I need
to redirect the request with the “/” at the end.
The statement below does NOT
work. What is the best way to write this.
elseif { not[HTTP::uri] ends_with “/” } {
HTTP::redirect “https://[HTTP::host][HTTP::uri]/”
else {
discard
It seems that the ends_with operator isn’t returning a boolean value (or at least that’s what is being inserted into the logs)
can’t use non-numeric string as operand of “!”
while executing “if { ! [HTTP::uri] ends_with “/” }…”
maybe unRuleY can chime in as to why. Since it’s not returning a boolean so you can’t use the not operator with it.
But, you aren’t out of luck, you can always use the built-in TCL string commands (Click here) to manipulate strings
Give this a try…
  if { [HTTP::uri] starts_with "/channel/" } {
    pool QA1
  } elseif {[HTTP::uri] starts_with "/performance/" } {
    pool QA2
  } elseif { [HTTP::uri] starts_with "/lead/" } {
    pool QA3
  } elseif { [string index [HTTP::uri] end] ne "/" } {
    HTTP::redirect "https://[HTTP::host][HTTP::uri]/"
    discard
Now, you didn’t state this, but your rule will only do the redirect if the above “starts_with” comparisions don’t pass. If you want this to occur even on those uri’s then you might want to move the ends_with piece to the beginning of the loop. Also, keep in mind, that some webservers won’t like appending slashes to file name requests (ie. /dir/somefile.htm).
-Joe
This is caused by something called operator precedence. The “not” operator (an alias for “!”) is of higher precendence than starts_with, ends_with or equals. So, what’s happening is that the not is being applied to the [HTTP::uri] operand and then the result of that is being checked whether it ends_with “/”. Clearly not what you want.
Try adding some parenthesis to tell Tcl want should happen first:
elseif { not ( [HTTP::uri] ends_with "/" ) } {
Thanks Joe , Your solution works! I will also try the other suggestion from unRuleY
