The “application verification failure” message is usually indicative of a certificate validation issue. I’d recommend to first manually validate the client certificate against the specified CA using the OpenSSL verify command:
The event is triggered. I have a rule which logs the cert count in that event, and it logs 0 regularly. Jim should look at the example in the Wiki: F5 Cloud Docs It does almost exactly what he wants. He will need to pick out the CN from the subject. e.g change the test to if { [X509::subject [SSL::cert 0]] contains “CN=my.common.name” }
Further to the point about when the CLIENTSSL_CLIENTCERT event is triggered, the Wiki says “Triggered when the system receives a certificate message from the client. The message may contain zero or more certificates”
