Iquesry is not working between LTM and GTM
pair of GTM and LTM in three DCs. GTMs are in Active standalone and ltms are in active standby mode
topology
GTM to switch vlan (10 ) LTM to switch (VLAN 10 ,20,30)
VLAN 10 is listner in GTM,self ip in LTM and l3 interface in sw VLAN 20 is self IP in LTM and l3 interface in sw
In GTM GSLB server list added GTM and LTM ( from vlan 20 IP )
LTM DG is VLAN 30 (sw IP) GTM DG is vlan 10 (LTM IP)
Forwarding VS is configured for VLAN 20 IP in LTM to forward the traffic whic is coming on VLAN 20
Problem
I am not able to add all the GTM and LTM through Iquery when LTM is DG for GTM when i changed GTM GW as SW VLAN 10 IP then all the servers in GTM shows green
Also notice that after configuring the forwarding VS in DC for VLAN 20 IP which is used in GTM to add LTM
local LTM server are showing green in local DC GTM but not the other DCs LTM and GTM showing green
Please help
i would add a picture, currently i don’t quite understand your setup. it sounds you might just walk through the iquery trouble shooting SOL.
