HI all, I`m looking for some references on IPv6 deployment
Basically I`m trying to build a POC for a large deployment we have in regards to IPv6
My questions are :
- How does the IPv6 translation occurs in Link Controller ?
- Are there any known limitation for iPv6 deployment that I should be aware of ?
(the 3dr Part devices I`m working with are Juniper M7 series, Cisco 2X series all are IPv6 compliant)
- Are there any internal manual with IPv6 deployment scenarios ?
The scenarios I`m trying to test are fairly simple:
- LC - Router - Internet
- Internal IPv4 - LC - Internet IPv6
- Internal IPv6 - LC - Internet IPv6
Thx in advanced if you can forward me to the appropriate links
