Hi All,
My facing a challenge to create IPSec VPN tunnel between two BIG-IP LC devices.
Internal >> Firewall >> LC >> internet >> LC >> Internal.
BIG-IP LC >> BIG-IP LC, is their any config or Links docs for reference to deploy.
Any Configuration or Steps to initiate or any Videos which help us to deploy such scenarios.
Shared version 12 stuff as think it is the most common used version at the moment but should be able to apply the same to version 11 or 13.
12.1.x: Manual: BIG-IP TMOS: Tunneling and IPsec
I am assume you are looking for IPSec in Tunnel mode between the F5 BIG-IPs:
12.1.x: Configuring IPsec in Tunnel Mode between Two BIG-IP Systems
