Looking for an irule that will replace the IP address of outgoing traffic with the FQDN. Issue is external server does not have a valid PTR record to allow resolution. Owner of this server does not want to add PTR and communication with this server is required. If there is a better way to address this issue please direct me to it.
Do you want to check the Host header on all requests through the VIP and if it’s one particular IP address, replace the value with a hardcoded value? If so, you can add an HTTP profile to the VIP and use a rule like this:
Check if Host header matches 1.1.1.1.
Use catch to handle non-IP Host values.
If IP::addr matches 1.1.1.1, $result will be 1
if {not ([catch {IP::addr [HTTP::host] equals 1.1.1.1} result]) && $result==1}{
HTTP::header replace Host "www.example.com"
If that’s not an accurate assumption of your scenario, can you clarify what you’re trying to do?
Aaron
If by "outgoing: you mean response traffic then you would need to use HTTP::header replace Location “www.example.com” is hoolio’s example as responses do not have a Host header. Also, if the IP address is embedded in the page you would need to use a stream profile to rewrite it. Since there seems to be only one host in question here a simple stream profile with the IP address in the Source field and the FQDN in the Target field should get it done. If there are multiple hosts in questions then you could do this with am irule:
when HTTP_RESPONSE {
Replace IP Addresses from HTTP responses
if { [HTTP::header value “Content-Type”] contains “text”} {
STREAM::expression “@1.1.1.1@host1.mysite.com@ @1.1.1.2@host2.mysite.com@ @1.1.1.3@host3.mysite.com@”
STREAM::enable
STREAM::disable
HTH,
Joe
Hi Joe,
Nice one. I wasn’t sure if the original poster was trying to rewriite an outbound request or response.
One note on the stream profile: it’s applied to request and response payloads of both text and binary content types. So it’s always a good idea to use an iRule to enable the stream filter only on the specific responses you want it for. Also, as there isn’t a way to update the content-length header in requests using a stream profile and iRule, a stream profile isn’t a valid option for rewriting request payloads when the find/replace strings are a different length.
Aaron
Sorry for any confusion in my explanation, I will try again.
We have a Apache web server that needs to send information to an external server. From what I am being told the encryption feature of this server is a resource hog so the F5 is needed for that task. The Apache server sends the information to the vip on the F5, the F5 encrypts the traffic and sends it to the pool member which is an external server. The issue I have is the node is defined by ip address 1.1.1.1 the external web server does not have a ptr record so reverse lookup will not work and connection fails. We are sending information to the external server there is no request nor is it a response. All traffic on this VIP will need to have the ip address changed to FQDN both values will stay the same.
Does this make sense?
So the client is a server in your network. That Apache “client” opens a connection to the VIP and is load balanced to an external host. Does that sound about right?
Who is doing a reverse lookup of the IP address to try to resolve it to a hostname? LTM doesn’t need to a FQDN in the HTTP host header for load balancing. By default LTM would just translate the destination address on the TCP packets to the selected pool member and send the HTTP headers on unmodified.
Is the device that needs to resolve an IP address inspecting the source or destination IP address on the packets or the HTTP host header value? Can you clarify what you’ve configured so far and what isn’t working?
Thanks,
Aaron
Yes that is correct other than there is only one external host. I guess no one is doing a reverse lookup/ the LTM tries to connect to 1.1.1.1 and connection fails. If I go to 1.1.1.1 from a web browser connection fails but if I go to site.com connection works! I have nothing more than a VIP and Pool configured right now.
Okay, so it sounds like the destination host might be filtering on the host header value in requests. You could try testing this from the LTM command line using curl to insert a host header:
curl -kv https://1.1.1.1/index.html -H “Host: www.example.com”
If that works, you should be able to use the iRule in my original reply to rewrite the host header to a static string. You’ll need to include a server SSL profile on the VIP to have LTM accept clear text HTTP from the client and establish an SSL handshake on the server side.
Aaron
Here is what I received
[root@:Active] config curl -kv https://1.1.1.1/index.html -H “Host: www.example.com”
* About to connect() to 1.1.1.1 port 443
* Trying 1.1.1.1… connected
* Connected to 1.1.1.1 (1.1.1.1) port 443
* error setting certificate verify locations, continuing anyway:
* CAfile: /usr/share/ssl/certs/ca-bundle.crt
CApath: none
* SSLv2, Client hello (1):
Unknown SSL protocol error in connection to 1.1.1.1:443
* Closing connection 0
curl: (35) Unknown SSL protocol error in connection to 1.1.1.1:443
Aaron,
Yes I am replacing ip and FQDN since this is on a public forum
Ran the following
[root@:Active] config curl -kv https://1.1.1.1:1234/service.svc?xxxx -H “Host: test.example.com”
* About to connect() to 1.1.1.1 port 1234
* Connected to 1.1.1.1 (1.1.1.1) port 1234
CApath: none
SSLv3, TLS handshake, Server hello (2):
SSLv3, TLS handshake, CERT (11):
SSLv3, TLS handshake, Server finished (14):
SSLv3, TLS handshake, Client key exchange (16):
SSLv3, TLS change cipher, Client hello (1):
SSLv3, TLS handshake, Finished (20):
SSL connection using RC4-SHA
Mike
Was the request successful? Was there anything in the curl output after the SSL handshake completed? For reference, below is a complete request to https://mail.google.com.
I notice you’re making the request to a non-standard port (1234). Do you have the same port configured for the LTM pool member(s)? Is the pool member marked up by an HTTPS monitor?
If so, what happens when a client makes an HTTP request to the VIP? Do you see a request to the pool member go out? You can use tcpdump to check this (tcpdump -ni 0.0 host 1.1.1.1 and port 1234).
Aaron
$ curl -vk https://mail.google.com
* About to connect() to mail.google.com port 443 (0)
* Trying 209.85.229.83… connected
* Connected to mail.google.com (209.85.229.83) port 443 (0)
* successfully set certificate verify locations:
* CAfile: none
CApath: /usr/ssl/certs
* SSLv3, TLS handshake, Client hello (1):
* SSLv3, TLS handshake, Server hello (2):
* SSLv3, TLS handshake, CERT (11):
* SSLv3, TLS handshake, Server finished (14):
* SSLv3, TLS handshake, Client key exchange (16):
* SSLv3, TLS change cipher, Client hello (1):
* SSLv3, TLS handshake, Finished (20):
* SSL connection using AES256-SHA
* Server certificate:
* subject: C=US; ST=California; L=Mountain View; O=Google Inc; CN=mail.google.com
* start date: 2009-12-18 00:00:00 GMT
* expire date: 2011-12-18 23:59:59 GMT
* common name: mail.google.com (matched)
* issuer: C=ZA; O=Thawte Consulting (Pty) Ltd.; CN=Thawte SGC CA
* SSL certificate verify result: unable to get local issuer certificate (20), continuing anyway.
> GET / HTTP/1.1
> User-Agent: curl/7.19.6 (i686-pc-cygwin) libcurl/7.19.6 OpenSSL/0.9.8l zlib/1.2.3 libidn/1.15 libssh2/1.2
> Host: mail.google.com
> Accept: */*
< HTTP/1.1 200 OK
< Cache-Control: public, max-age=604800
< Expires: Tue, 02 Feb 2010 17:45:59 GMT
< Date: Tue, 26 Jan 2010 17:45:59 GMT
< Refresh: 0;URL=https://mail.google.com/mail/
< Content-Type: text/html; charset=ISO-8859-1
< X-Content-Type-Options: nosniff
< X-XSS-Protection: 0
< X-Frame-Options: SAMEORIGIN
< Content-Length: 234
< Server: GFE/2.0
No connection will work if I use the actual FQDN but fails if I use the ip and host command with HTTP/1.1 400 Bad Request.
This connection is not a standard HTTPS web site there is a client server service that will be running on both sides so replacing the ip address with the FQDN I believe is the only issue. Pool members are configured with service port 443 wouldn’t that be the port I would want for the encryption?
So you could try configuring the VIP on port 80, the pool member(s) on port 443, and add the iRule. If you give that a go and it doesn’t work, can you add logging to the iRule to make sure the Host header replacement is being done?
Aaron
ok, what would the logging look like?
Are you an F5 employee?
If so is there a secure location where I can share all the sensitive information?
Mike
Hi Mike,
No, I work for an F5 partner in the UK. If you want official F5 Support or consulting you can contact F5.
Can you try testing the VIP, pool and iRule? You could add logging like this:
log local0. "[IP::client_addr]:[TCP::client_port]: [HTTP::method] request to [HTTP::host][HTTP::uri]"
log local0. "[IP::client_addr]:[TCP::client_port]: Matched IP check for 1.1.1.1. Replacing host header"
when SERVER_CONNECTED {
log local0. "[IP::client_addr]:[TCP::client_port]: Connected to [IP::server_addr]:[TCP::server_port]"
Aaron
OK, thanks, actually think I am getting better support from you!!
I will add this irule, give it a try, and let you know
Thanks again
Mike
Aaron,
Yea I know they sent me here…
So I added the rule and am receiving the logs
Jan 28 13:48:15 tmm tmm[1616]: Rule Test_Log : 10.10.101.183:1461: Connected to 1.1.1.1:443
So I am guessing I have something wrong in my replacement rule
HTTP::header replace Host “example.com”
log local0. “[IP::client_addr]:[TCP::client_port]: [HTTP::method] request to [HTTP::host][HTTP::uri]”
log local0. “[IP::client_addr]:[TCP::client_port]: Matched IP check for 1.1.1.1. Replacing host header”
log local0. “[IP::client_addr]:[TCP::client_port]: Connected to [IP::server_addr]:[TCP::server_port]”
So that log line shows the connection being established with the server. Do you see a log line from these two previous log lines?
Aaron
Jan 28 13:58:50 tmm tmm[1616]: Rule Test_Log : 10.10.101.183:1688: Connected to 1.1.1.1:443
Jan 28 13:58:51 tmm tmm[1616]: Rule Test_Log : 10.10.101.183:1689: GET request to 2.2.2.2:1234/Example.svc?wsdl
Jan 28 13:58:51 tmm tmm[1616]: Rule Test_Log : 10.10.101.183:1689: Connected to 1.1.1.1:443
Jan 28 13:58:53 tmm tmm[1616]: Rule Test_Log : 10.10.101.183:1690: GET request to 2.2.2.2:1234/Example.svc?wsdl
Jan 28 13:58:53 tmm tmm[1616]: Rule Test_Log : 10.10.101.183:1690: Connected to 1.1.1.1:443
1.1.1.1 is external pool node address
2.2.2.2 is internal VIP address
Okay, so the iRule is looking for a request which contains the host header of 1.1.1.1. If the VIP is 2.2.2.2, then you can change the rule to check for 2.2.2.2. Or if you just want to rewrite the host header for all requests, you can remove the if check:
Replace the host header with www.example.com
Aaron
