IP::stats age problem
I am using an iRules pretty much the same as the following to calculate the response time of a HTTP request and respond.
    set reqAge [IP::stats age]
    set reqURI [HTTP::uri]
    set reqClient [IP::remote_addr]:[TCP::remote_port]
 when HTTP_RESPONSE {
    set respTime [expr {[IP::stats age] - $req_age}]
    log local0. "Client at $reqClient requested $reqURI. \
Server response was received $respTime milliseconds after the request was sent to the server."
But when I looked into the log. There are negative number in the Response Time field(TCP_AC = CLIENT_ACCEPT, HTTP_RQ = HTTP_REQUEST, HTTP_RP = HTTP_RESPONSE, RT = Response Time)
TCP_AC,2010-09-20 18:28:54,12849785341334,8,00000, Age:130
HTTP_RQ,2010-09-20 18:29:00,12849785341334,8,00017, GET,www.nownews.com,{| http://www.nownews.com/common/ticker.htm |},{| mozilla/5.0 (windows; u; windows nt 5.1; en-us) applewebkit/534.3 (khtml, like gecko) chrome/6.0.472.59 safari/534.3 |}, LR:-52, Age:5882
HTTP_RP,2010-09-20 18:29:00,12849785341334,8,00018, ST:200, CT:text/html, CL:1973, RT:-23, Age:5859
And I saw some connection age were reset when response:
HTTP_RP,2010-09-20 18:20:46,12849780461284,8,00002, ST:200, CT:text/plain, CL:10, RT:-119, Age:2
HTTP_RP,2010-09-20 18:20:46,12849780461285,8,00002, ST:200, CT:text/plain, CL:10, RT:-138, Age:2
HTTP_RP,2010-09-20 18:20:46,12849780461286,8,00002, ST:200, CT:text/plain, CL:10, RT:-138, Age:2
HTTP_RP,2010-09-20 18:20:47,12849780471287,8,00002, ST:200, CT:text/plain, CL:10, RT:-157, Age:2
HTTP_RP,2010-09-20 18:20:48,12849780481290,8,00002, ST:200, CT:text/plain, CL:10, RT:-159, Age:2
Could anyone explain this? Many thanks.
Are you running 10.x? I see from the wiki page where that iRule is posted that there’s an issue with IP::stats on v10
http://devcentral.f5.com/wiki/default.aspx/iRules/IP\_\_stats.html
Also - are you using OneConnect or anything that would mess with age?
Oh yes I forgot to mention that it is running on 10.x
Let me check on ask.f5.com to see if there are issue
The virtual server have no other profile except HTTP and TCP
