IP forwarding VS timeout issue
I have enabled IP forwarding to internal VLAN and seems working. However, I have an application that fails after 300 seconds timeout.
Is there a way to disable timeout for certain IPs on the forwarding virtual server?
Here is what I got:
virtual Forward_Inbound {
ip forward
destination 10.10.1.0:any
mask 255.255.255.0
Appreciate your help!
That is the default idle-timeout for fastL4 profiles. Create a new fastL4 profile with the timeout disabled, then apply to your forwarding virtual:
profile fastL4 notimeout_FastL4 {
   defaults from fastL4
   idle timeout indefinite
ip forward
profile notimeout_FastL4
mask 255.255.255.0
Thanks for your help citizen_elah! I just figured it out myself playing with profiles. Appreciate your prompt response.
i heard f5 guys does not suggest indefinite timeout.
zafer
I don’t think an indefinite timeout is recommended as managing each connection uses memory. Also, SOL7166 indicates that using an indefinite timeout disables the PVA for that VIP. I’d think a timeout greater than 300 seconds and less than indefinite would be more ideal.
Aaron
