I currently have an iRule in place to do ip filtering in multiple places in a website. I had an oversight when this was first written and failed to put a rule in for the entire website.
if { [string tolower [HTTP::uri]] eq "/t/lccc/" } then {
if { [class match [IP::client_addr] equals /Education/tableau_lccc] } then {
Let the request pass...
HTTP::respond 403 content "Access Denied"
} elseif { [string tolower [HTTP::uri]] eq "/t/wwcc/" } then {
if { [class match [IP::client_addr] equals /Education/tableau_wwcc] } then {
} elseif { [string tolower [HTTP::uri]] eq "/t/nwccd/" } then {
if { [class match [IP::client_addr] equals /Education/tableau_nwccd] } then {
} elseif { [string tolower [HTTP::uri]] eq "/t/nwc/" } then {
if { [class match [IP::client_addr] equals /Education/tableau_nwc] } then {
} elseif { [string tolower [HTTP::uri]] eq "/t/ewc/" } then {
if { [class match [IP::client_addr] equals /Education/tableau_ewc] } then {
} elseif { [string tolower [HTTP::uri]] eq "/t/cwc/" } then {
if { [class match [IP::client_addr] equals /Education/tableau_cwc] } then {
} elseif { [string tolower [HTTP::uri]] eq "/t/cc/" } then {
if { [class match [IP::client_addr] equals /Education/tableau_cc] } then {
From this point I would like to add something to filter the top level of the site, using each of the above data groups. Would this go after the final “else”? Also, is this the proper way to refer to multiple data groups?
} elseif { { [string tolower [HTTP::uri]] eq "/" } then {
if { [class match [IP::client_addr] equals /Education/tableau_cc, /Education/tableau_cwc,/Education/tableau_ewc, etc, etc, etc ] } then {
/Education/DG_URI containing URI as key and the list of allowed roups as value
/Education/tableau_global containing IP addresses as key and the group membership as value
Then use following irule.
Search if the URI have an IP address restriction, store the allowed groups in a variable
if { [set AllowedGroups [class match -value [string tolower [HTTP::uri]] equals /Education/DG_URI]] ne "" } then {
Search if the IP address is known in a the IP addresses Datagroup and filter based on previous search
if { [set IPGroups [class match -value [IP::client_addr] equals /Education/tableau_global]] ne "" && ($AllowedGroups contains $IPGroups)} then {
If you want to stick to your existing iRule structure then take a look below to see how multiple data-groups can be queried in a serial manner for
[HTTP::uri] eq /
Note: But I second Stanislas opinion, that an approach with just two data-groups (one to identify the IPs and a second one to identify the URI) makes way more sense (e.g. easier to maintain, better flexibility).
set low_uri [string tolower [HTTP::uri]]
if { $low_uri eq "/t/lccc/" } then {
} elseif { $low_uri eq "/t/wwcc/" } then {
} elseif { $low_uri eq "/t/nwccd/" } then {
} elseif { $low_uri eq "/t/nwc/" } then {
} elseif { $low_uri eq "/t/ewc/" } then {
} elseif { $low_uri eq "/t/cwc/" } then {
} elseif { $low_uri eq "/t/cc/" } then {
} elseif { $low_uri eq "/" } then {
if { ( [class match [IP::client_addr] equals /Education/tableau_lccc] )
or ( [class match [IP::client_addr] equals /Education/tableau_wwcc] )
or ( [class match [IP::client_addr] equals /Education/tableau_nwccd] )
or ( [class match [IP::client_addr] equals /Education/tableau_nwc] )
or ( [class match [IP::client_addr] equals /Education/tableau_ewc] )
or ( [class match [IP::client_addr] equals /Education/tableau_cwc] )
or ( [class match [IP::client_addr] equals /Education/tableau_cc] ) } then {
Note: I’ve changed your existing syntax slightly so that LTM computes the lower URI just a single time (aka.at the beginning) and then reuses the computedresult for the individualstatements.
Thank you for all these answers everyone. I’m going to go with Kai’s as a quick fix, but implement Stanislas’s answer once I can get the data groups merged.
