I am working on a project that involves using the F5 Big-IP to inject a header for a range of countries based on IP address. There are around 20+ countries and about 7000+ ip ranges (address + netmask) that are in those 20+ countries. Each country, when detected, will get its own version of the header.
This all has to be created programmatically through iControl API - currently using Perl. My thought is to add 20+ data groups (which would each contain some portion of these 7000+ ip ranges) and associate an iRule for each data group.
Thus, an incoming request will have to pass through match checks on 20+ data groups, each with a large number of ip ranges.
My questions are:
- is the F5 likely capable of handling this quantity of address values in data groups?
- will there be significant performance hits with this design?
- is there a better suggestion for how to do this? What is the optimal manner in which to handle large quantities of ip ranges in the F5?
