Can anyone confirm how LTM handles flows from internally defined nodes which use the LTM as its gateway.
For example a web server that needs to communicate to an NTP or DNS server logically on the external side of the LTM. Does any configuration need to be done in order to achieve this.
Regards
Miron
Yes, LTM is a default deny device. You either need to SNAT or NAT internal connections to an external IP address, or use a wildcard forwarding virtual server (0.0.0.0:0) to allow the traffic in and out. If any NetBIOS is involved the NAT/SNAT method probably won’t work, so I tend to prefer the forwarding virtual method. When using that, the LTM’s gateway will likely need a static route to the network behind LTM pointing to the LTM’s external address (floating address for redundant pairs).
Denny
