I have an irule configured on the LTM that I apply to most of the Virtual Servers that sends the traffic logs to a Splunk server. Lately, i have noticed logs not being in Splunk. On the splunk server, i have created several Data Input Ports other than UDP/514. If i go to the server pool that contains the splunk server and change the port number, as soon as it updates, I start seeing the logs in the splunk again. This will work for awhile and then it would happen again. I would go into the server pool and change to a different port and then it would start working. I ran a capture on the splunk server during the time that it wasn’t working and i see the logs coming from the LTM, but the protocol is WHO instead of UDP. When it is working, the captures show the protocol as UDP. I thought it was an issue with Splunk, so i opened a case with them. While waiting for a response from Splunk support, the issue happened again and this time i ran a capture on the LTM. The LTM capture also shows the protocol as WHO instead of UDP. Here is a copy of an entry from the capture.
11 2020-02-28 08:49:12.408140 10.42.104.11 10.42.104.230 WHO 249 14.82.39:53753 → SNAT: 10.48.20: 8251108.39 5398359.36 14476452.42
Has anyone ever experienced this before? We have LTMs in other environments that are running the same irule and i never had this issue with them.
For reference, here is the irule config:
# set the URL here, log it on the response
set url [HTTP::header Host][HTTP::uri]
set vip [IP::local_addr]:[TCP::local_port]
set hsl [HSL::open -proto UDP -pool splunk]
when HTTP_RESPONSE {
set client [IP::client_addr]:[TCP::client_port]
set snat [IP::local_addr]
set node [IP::server_addr]:[TCP::server_port]
set nodeResp [HTTP::status]
# log connection info
HSL::send $hsl “Client: $client → SNAT: $snat → VIP: $vip → URL: $url → Node: $node with response $nodeResp”
