recently we migrated from v10.2.4 to v12.1.2 and since then we are seeing most of applications are facing issue. The major change I know is related to ciphers hence I have selected serverside ciphers as “serverssl-insecure-compatible” but still we are seeing intermittent disconnect. Is there any another way we can find the reason for disconnect.
Also one thing I noticed that at server “TLSv1.2 112 bits ECDHE-RSA-DES-CBC3-SHA Curve B-571 DHE 570” is configured while if I check on F5 same cipher ECDHE-RSA-DES-CBC3-SHA is showing but with 168 bits. Please suggest.
